Arlo Q offline
  • 4600 Views
ferrarigreg
Hi there,  After moving house may camera amber light comes on for about 30 seconds then turns off.   Reset does not help.   If I leave it plugged in the back of the camera gets ward to touch.
philfeldman
My Arlo Q does exactly the same thing. Solid Amber light. Cannot get blue blinking light to Sync. Need help! Please let me know what you find out!
[email protected]
Try removing the camera from Settings, My Devices and resync it as if new. You may also want to hold the reset button until the camera clicks and the LED flashes amber. Let it reboot and tray again.
philfeldman
Thanks so much. I will definitely give this a try tonight and let you know how it goes!
