Dear Arlo Team,
my Arlo system contains of several Arlo HD and one Arlo Q.
My Arlo Q is recently only showing recorded pictures based on motion detection, but can't show any live pictures (app says "device is not connected" - which is obviously not correct as still recordings are being transmitted). I tried to re-connect the Arlo Q (both to the current network as well as to another network), but no success.
Any recommendations what to do?
Best regards,
Sascha
Hi Dr_S_HG,
Are you seeing any LED lights showing when trying to view live on your Arlo Q camera? Is the error showing when you're trying to view on the Arlo app on your phone device and/or the web client on your computer?
Hi,
Sascha
You mentioned that your light is flashing frequently, do you know what LED color it would be showing? You can refer to here on the LED lights: What do the different LED behaviors on my Arlo camera mean?
Arlo Q
