Arlo Q not recording movement when scheduled
  • 5 Replies
  • 3601 Views
Brother_Bear
About the middle of Dec. 2016 my camera stopped recording when motion should set it off. If I use the app on my iPhone and manually record then it works.
Camera: on.
Mode: Armed
Motion and Audio detection: on
Does not record with motion in front of the camera
Live video: Working
Manual recording from the app: working
Please help.
The next step would be to reset the camera. Use the reset button until the camera clicks and the LED flashes amber. Resync. Any luck?
5 REPLIES 5
Try restarting the camera. I have a case open right now about no videos in the library for a couple of days although the CVR timeline shows that videos supposedly were recorded, just not in the library. A restart caused recordings to be deposited in the library again.
Brother_Bear,
Did the suggestion above help resolve the issue? Please let us know.
Brother_Bear
No. It didn't help. I unplugged it and waited about 30 sec. then plugged it back in. Still no joy. I am open to other suggestions.
Thanks for replying.
Brother_Bear
I believe that fixed it. You guys are awesome. Thank you so much. Have a great day.
