Arlo Q live view works fine on mobile app, but buffers constantly in website.
  • 1 Reply
  • 1172 Views
etvansego
When using the website (if it even works at all) I get about 20-40 seconds of buffering, then 1-2 seconds of live view, then back to buffering. There is no buffering with the app. All tested on the same network.
Problem with website is on all browsers and devices. My main computer I try to use it on has a wired 300/300 Mbps connection.
Camera connectivity isn't an issue. They are right next to an access point that has no problems when tested with other devices.
Any ideas?
That is quite odd. I'd suggest turning the cell service off on the phone to ensure that the WiFi-only connection is working properly.
What is the computer's OS? What browser? Have you tried using an incognito tab to access Arlo (which disables all extensions that may be interfering with the stream somehow)? How about using a different browser and even a different computer?
