  • 2047 Views
yamhab
during set up the light goes blue, scan the code, and the camera blinks blue, slowly till it sqwauks and goes back to flashing amber
JessicaP
Hey @yamhab,
Could you send a video of the sound your Arlo Q makes after setting up?
Lloyd10
I’m having the same issue on a brand new system. Added two of the Pro wireless cameras, updated firmware on base and cameras, went to add the Q and it tried and failed. I tried logging in, resetting base and Q but no luck. Help
JessicaP
Hey @Lloyd10,
Are you setting up your Arlo Q with an iOS or Android phone? Make sure your mobile device and your Arlo Q camera are connected to the same network (2.4 GHz).
