Arlo Q: impact on wifi bandwidth?
  • 5 Replies
  • 9044 Views
  • 2 Likes
devotchko
Luminary
Luminary
Since the Arlo Q cameras are always broadcasting video, even when UNARMED, and since they do not connect to the base but to your own WIFI network, does this mean that some bandwidth is always taken up by the camera, even when it is not activated? Any official word on this, Arlo?
5 REPLIES 5
HUH! Dunno why I hadn't thought to check that. Using the router's interface, I see 40-42kB/s outgoing and 1-2kB/s incoming. Steady stream...
Edit: forgot to mention that this is at 1080p.
devotchko
Luminary
Luminary
Well, if this is all that is constantly streaming while the camera is deactivated that would not be too bad, even for 2 cameras. Can anybody else chime in?
Just did a check...
Motion activated on Q cam... very little band width prob a few k but nothing really to worry about
Running live view or record mode.... steady 300-500k ,  with regular peaks to 1.5mb/s every sec or so
Edit ..what I really noticed was the diff between the UP and the DL while watching a live view... can you say compression
As A PS.... here's the specs from Netgear;
How much of my internet connection’s bandwidth does Arlo Q video streaming use?
Arlo Q cameras use the following bandwidth when they are streaming:
1080P = 1500 kbps
720P = 700 kbps
480P = 300kbps
360P = 200kbps
240P = 100kbps
However, when you are not logged in or when there is no motion, bandwidth is reduced to about 100 kbps at 1080P.
devotchko
Luminary
Luminary
I tried looking for this info myself before I posted, but couldn't find it. Thank you for posting this.
