  • 1 Reply
  • 2764 Views
Wkuehnis
Hi,
I changed the settings. Example: disabled the sound, set a region and set a level for the recognition.
Because I was in the room for some time, I disabled it, then I enabled it again.
Problem:
All the settings were lost.
Willi
Do a reset of the Q by holding in the reset for about ten secs... resync.
Also the SAVE for settings may not be on the same page as the adjustment ( some times use Back( upper left) as save is on previous page )
