Arlo Q field of view has changed! No option of changing? Attached picture.
  • 2 Replies
  • 2311 Views
Goldnwolf
My Arlo Q – wired camera used to have a much wider field of view. There is no option to change in settings. I will attach a picture of the view it used to have and a picture of the view it has now. The previous picture the camera was about a foot away from the wall behind it now it’s pushed back a little bit so you can actually see the top of the piano that is sitting on so it should have a wider field not less. As I said there’s no way to change it in the settings so I’m assuming Arlo corporation made some sort of change? (Can’t seem to attach two pictures but the description I’ve given should be sufficient the pictures are just for “proof“)
Sounds like you've got some pinch zoom going on in the cameras video settings. Check out the snapshot there.
Goldnwolf
Thank you for responding! It took me a little while to figure out what you meant but i got it. Thanks!
