  • 2 Replies
  • 3503 Views
HugoCH
I bought for the first time a Netgear camera : the Arlo Q. Installed 1 week ago, works perfectly, very happy.
However I noticed that if WiFi goes off and on again, the camera doesn't reconnect to WiFi automatically, I have to re-sync it with QR code (the camera is connected to WiFi directly, not to a box).
It is fine, but this means I can't do it if I am not home.
Is it normal the camera doesn't reconnect automatically to WiFi?
thanks
Normal fix for the Q is to RESET it.... hold in reset for ten secs till the led flashes amber...
Then resync again and test to see if it auto reconnects in future.
If not , contact Netgear Support
My Q, which seems to be developing a weirdness, sometimes won't reconnect when I play with the router's WiFi.  A power cycle fixes it.
