Arlo Q - does noise trigger the camera? If so can senstivity be reduced?
  • 2 Replies
  • 3319 Views
JJOC
I use my ArloQ in my porch, which is very effective. However it appears to detect cars coming around the corner (engine noise) as no visual movement so I was wondering if the mic sensitivity could be reduced? As I can see any ability to configure. I've reduced the video area to see if this would help but to no avail. Any ideas?
Yes, there is a slide adjust bar for the mic sense level
go to MODE, Pick Q mode your using, then camera  to edit
where it says AUDIO IS DETECTED, click on the > to edit
adjust slider bar ( lower is less sense ), then use BACK at top left of page
SAVE is on bottom of page
JJOC
Great thx Tom, sorted did the trick 👍.
