  • 10 Replies
  • 4502 Views
crabbymike
Just installed an arlo q at a business, and trying to schedule so it just records but no motion, as there is a busy street that it just keeps firing me motion alerts all night. I have it scheduled from 8pm until 3 am, as getting vandalism, but phone is constant bing bing bing....what can I do?  TIA
10 REPLIES 10
crabbymike
I also did purchase the DVR package that does constant video recording 24/7 but just need it to record from my scheduled times of 8pm until 3am, so i can find out who is damaging things all the time.  Dont need the motion, as I can just go back to recordings?
Your choice appears only to turn off the alerts... you will have the recordings
In addition to turning off the notifications, you could use the Disarmed mode and just use CVR.  Then it would be like other systems which record but it's up to you to find the action.
crabbymike
Ok, does the CVR automatically record or is there a feature I have to turn on? I am cool turning off the motion and sound, and just have to go find when someone has tampered with my stuff?  thx
Yes..... it auto records.  AND if you turn off the alerts, in the CVR a motion trigger or sound trigger show up on the time time as a colored bars ( diff color for each , motion or sound )
Otherwise you may have to view hours of video to find what you want
crabbymike
Thx for your help! I will try that.
crabbymike
How do I access cloud? Is that the same as my library?  cannot find where the video is being recorded to? Sorry, just trying to figure this out
Yes, the library is the cloud.
crabbymike
Ok, I will wait, as I have it on disarmed, and do not see anything in the library, other than a clip of when I had it armed today. So must be once a day it downloads it into there?  thx
If things are disarmed, nothing iss recorded so nothing will go into the library. All videos are uploaded to the cloud as they occur.
