I have an Arlo base station with 4 wireless cameras. I am trying to add an Arlo Q to my network. My router is a Netgear 6300 to which my Arlo base station is attached via cable. The Arlo Q unit blinks yellow, then when I hold the sync button down it flashes blue. At that point I point the camera at the image on the computer screen the unit makes a chiming sound and the unit tries to connect to the network. It tries for about a minute and then makes a DahDum sound and goes back to flashing yellow. I have also tried to use the WPS on my Netgear router to make a connection. That also tries to connect, after a while it times out and I get a screen instructing me to reset the Arlo Q using a paper clip. I have tried that and nothing works. I am using Windows 10 Pro with the latest drivers. The other Arlo cameras are working fine. Can I get some help?
Arizphys, everyone in this thread who posted that they could not initially get connected to wifi, did get connected and they posted that their solution was getting the wifi name and password correct.
Yes... as mentioned the biggest problem in the SSID(network name) and password during setup... they have to be exactly right ( caps count ).
Also take time to check what the flashing of the leds mean;
Wireless Network Mode: Mixed
Wireless Network Name:
Aksesspunkt 1
Wireless Channel: 4 - 2.427 GHZ
Wireless SSID Broadcast: Enable
Security Mode: WEP
Default Transmit Key: 1
WEP Encryption: 128 bits 26 hex digits
Strongly suggest you change your WiFi security to WPA2. WEP can be fairly easily broken, letting intruders into your network.
Seems like the router may need a firmware update or just needs to be replaced so compatibility is improved. As long as you're comfortable...
I would try a firmware update on the router maybe? I have no issues connecting my cams on WP2 through my Apple TC router. WEP is seriously weak and even the rudimentary skilled could get in within seconds. Good luck.
Yes do share
interested to know...plse share
I will say this…
It has absolutely nothing to do with the users Wi-Fi system. (With the exception of user error In remembering passwords) Continuing to have people mess about with their router/WiFi can cause more problems. Also despite the insistence of the tech support person who failed to listen to anything I had to offer and was more insistent in having me do the exact same thing that didn't work the first 6 times the Arlo Q is not limited to functionality to the 2.4Ghz WiFi channel only. I'm currently up and running fine on a 5 Ghz channel.
Kudos to the Arlo Q hardware team. I was seconds away from shipping both cameras back and being done with the whole mess. However, after I managed to find a workaround to the two main install bugs, I am most impressed with the image quality (especially low light) and functionality of the camera. They really saved this from being yet another return. I applaud their fine work.
Thanks for the story,....wish you would post more.... but ok.
btw, yes we knew the Q works on 2.4 and 5ghz band.
As to compensation, don't hold your breath 🙂
Cuellar wrote:
If you could somehow locate the Recording of that session I believe you'll find it quite shocking as to how that call was handled
I feel your pain... I've called tech support in the past and knew more about the product then then did.
My last call went thru two people and no one had an answer other than " we'll call you back ". Sorry to say when you export service calls, you get what you sometimes pay for.
So let's summarize: you just filled several pages of the forum telling us that you're smarter than anyone at Netgear, whining about your support experience, complaining about Netgear's alleged incompetence, and then you won't help anyone else because you feel you should be compensated for all the time you spent. This forum exists for us to help each other but you're more interested in your ego than in sharing. Why didn't you just keep all this to yourself since you weren't going to contribute anyway? Oh yes, I remember, you wanted us to know that you're smarter then everyone. Interesting that your time spent on the phone was so valuable, but you had plenty of time to waste ours with your useless bragging and whining. Thanks
Arlo Q
