Arlo Q camera Zoom
Menard Aspirant
I have Arlo Q camera, and since i do my app update on my iPhone 6, i can't zoom more then 2x! It's a bug ?
JamesC Community Manager
This issue has been resolved in the latest version of the Arlo iOS mobile app. Be sure to check the app store and update to the latest version of the Arlo mobile app: Release Notes - iOS App 2.4.7 - 7th March 2018
All Replies
Menard Aspirant
Menard,
Could you provide more detail on the issue? What is preventing you from zooming? Are you getting an error message?
Menard Aspirant
Since I made the update of the Arlo application on my iPhone: version 2.4.0. I can zoom up to 2x, before I could zoom up to 8x. I have a Arlo Q camera
I have no error message.
it's the same thing on a another iPhone .
Menard,
I have escalated this topic for review. I will post an update when I have more information.
LowShack Aspirant
I have noticed the exact same issue
Pinkpeony Initiate
I have the same issue as well. Used to be able to zoom 4x and now can only zoom 2x. This started a couple weeks ago
Pinkpeony,
Biddy-r Star
Any news as to when this issue will get resolved?
Biddy-r,
Engineering is investigating this issue. I will post an update when I have more information.
Hackman88 Aspirant
is there any way  i can download the old version of the app seem that version working perfect  than the new version
im using iphone and android   app. thnks
Model: Arlo Q Plus Security Camera with Audio|Ethernet|PoE VMC3040S
alienz Guide
I have the same issue and it's a real pain. I rely on the zoom feature and now I can't go past 2x. There is no error message, the app is just incapable of going further.
Running on version 2.4.0 on an iPhone 6, iOS version 10.2
Biddy-r Star
Just updated, was hopeful this would see resolve, it's not, still the same.
Arlo are being very slow to sort this out...
Biddy-r Star
alienz Guide
Yeah, it's clear that one of the updates they rolled out put a hard cap on the zoom limit. This shouldn't be a very complicated fix.
Laurie696 Initiate
Hi JamesC <Modertor>.
I acknowledge you have escalated the issue but I don't see why we need to come to this forum to highlight this: don't take features away from consumers. If anything, add or improve features. The ability to live zoom is a large reason I chose your product compared to competitors. It has been over 3 weeks now without this functionality! The ACCC here in Australia take products maintaining "fit for purpose" very seriously. I may need to contact them if you cannot get this resolved promptly.
Boskobuha Guide
I have same issue and also 1080p is no available.
Guru jguerdat Guru
Where are you checking for this? It's in Settings, My Devices, your camera, Video Settings.
Boskobuha Guide
In settings it is 1080p but video quality is bad for sure it's not 1080p. I checked internet speed and everything is fine. This happens right after i update app
Guru jguerdat Guru
Download a video and use software to check the metadata embedded in it. There's various parts to the quality of the video and resolution is only part of it (remember that 1080p is only about 2 megapixels which even cheap cellphones beat).  Compression reduces the apparent resolution.  Resolution can be reduced due to network speeds anyplace between the camera and the servers - the system tries to adjust to maximize video within network constraints. If multiple cameras are recording at once your upload speed may be swamped leading to issues.
Post an example - we can at leqast tell you if it's normal or not.
Boskobuha Guide
I know how it looks HD video and i use this camera already few months and everything was perfect. Even if internet speed is bad video was good quality with interruptions but now quality simply is bad... and second thing is zoom 2x only, but with this quality of video no any sense to zoom more...
Rbroldan0507 Aspirant
Same problem, doesnt zoom to 8X as before 2X max. 4 of my family has the same problem. That's the reason why we liked Arlo to begin with. This feature. now its gone. Can we return?
Nethalite Apprentice
Having a zoom issue. When I fullscreen it I can only zoom 2x and when don't fullscreen size it it only gives me 3x zoom. Would like full screen to zoom more then that and I remember it gave me 8x zoom
