Arlo Q VMC3040 Won't Be "Discovered" By App Or My Computer After Reset
The camera suddenly stopped recording. When I tried to rediscover it, the blue light stops, goes to blinking amber and says that discovery wasn't successful. I tried factory reset several times, different router network, used computer vice app on phone, etc., and nothing works. Help!
Remove it from Settings, My Devices also and try syncing again.
I tried that previously, and again just now and it still doesn't work. After the blue light is on and it gives me a chime, the app searches for the device and I get a sound from the camera, then about a minute later, it says No Arlo devices found. The phone is on the same network as the camera. The camera reverts to a blinking amber light. The device does not show up on the Arlo app and I can't discover it. Help!
Might be worth trying to sync on a computer browser.
OK, just tried that again using Chrome on a iMac. Wouldn't disocver so suggested I reset to factory settings which I did and still no joy. Help!
You're holding the reset button until the camera clicks and the LED flashes amber, right? If so, swap at the store.
Yes, when I reset it, I put the pin into the reset hole on the side of the camera until it flashed amber, about 10 seconds. Swapping at the store? I ordered it from Amazon this past August so am sure it's out of warranty. Or is it? Not a good product if it fails this quickly.
You have a 1 year warranty. Open a case with support here for a hardware problem:
Arlo Q
