Arlo Q Solid amber light
  • 1 Reply
  • 4124 Views
ArloUser1201
I bought a Arlo Q and as soon I plug it in, it stays solid amber. I hold reset for 30 seconds+ and nothing happens. Unplugging it and replugging and even leaving it unplugged for a bit does nothing. I know it is functioning because it did blink amber at one point and time but now it refuses. Help!
brh
@ArloUser1201
If you are holding down the reset button for more than 10 seconds and the amber light does not start flashing, you probably have a defective device. In my Google searches I have found no other solutions for this. Contact Customer Support at the green banner near the bottom of this page.
Brian
