  • 4 Replies
  • 6090 Views
  • 2 Likes
Tatoosue
All of a sudden, my Q stopped working and is showing "offline."  I have tried everything that I know to do.  I have initiated the factory restart, still will not reconnect.  My wireless' cameras are fine.  Can someone please help?!?
Go to SETTINGS>MY DEVICES>pick q cam and use REMOVE DEVICE
Do a reset of the Q cam by holding in the reset in for about 10 secs till the front LED flashes...
Bring back the Q as if new ( ADD DEVICE )
Tatoosue
Thank you soooo much.  I am still at work, so I will have to try that when I get home.  It just about wore me out last night - I finally just gave up!  Thanks again.
RandyWe
I have exact same problem. 1 out 100 times it will work when I open app. I will get notifications of movement detected even though app shows Arlo Q offline. I'm unable to see a recording for the motion detected when camera shows offline. I'm also unable to control it. I've removed it from my account done a factory reset. None of these things work. I have a base with 3 wireless Arlo cams that works flawlessly but the Q isn't functioning even when setup is successful.
