  • 4 Replies
  • 2279 Views
snag
Trying to set up Arlo Q.  Problems with "discovering device".  "Taking to long to dicover, view set up instructions again"  "Unable to find your Arlo Q".
I reset, with the same results.  Trying to view with Iphone.
You said reset... but did you hold the reset for ten secs till the front led flashed ??
this usu solves the non-finding issue
snag
HELD IN TILL FLASHING AMBER.
snag
I tried reset three times, till amber blinking LED.  No success.
Contact Netgear Support
