Arlo Q (Model: VMC3040). Will not connect to WiFi.
  • 7 Replies
  • 6282 Views
  • 4 Likes
  • 5 In Conversation
FrannieM
 My WiFi is up and running, I checked with my provider (Verizon).
I found both my cameras  blinking amber when I woke up this morning.
I tried to connect to network (Fios), put in my password, wait for
blue flashing light on camera, then hold up my phone to camera for
the QR code. The cameras chime. Then I get the amber flashing light again.
Ive done this numerous times.
FrannieM
There was an issue with my wifi.
Once that was resolved, my cameras came back on line.
thank you.
7 REPLIES 7
Have you tried just unplugging them, pause and then plug back in?
FrannieM
thank you.
cosmicstyle
Could you please share what WiFi issue you had and solved?
I am having the same problem to reconnect.
I did probably everything I read in this community, but did not make it yet;;;
Thanks in advance!
JessicaP
Hi @cosmicstyle,
Try to restart your router if you haven't already to see if that helps.
SilvPongo
I'm also having this problem only on 1 camera. I have 2 1 of them is working perfectly but the other 1 connects I get the Blue chime then 5 seconds later I get an amber light with a flat buzz noise. I have done a multiple of stuff to get it working but it's not.
FrannieM
Thank you.My issue has been resolved.
