  • 14 Replies
  • 6795 Views
Cyrano
I'm trying to create zones, but they are not sticking. I defined three zones, and confirmed they were really defined by switching away from Settings, then back again. However, a few minutes later, 2 of the 3 zones are missing.
14 REPLIES 14
Cyrano
The problem is persistent. I created this zone:
Then I simply refreshed the browser page, and got this:
Hula_Rock
Prodigy Prodigy
Prodigy
EDIT:  getting the same thing
Hula_Rock
Prodigy Prodigy
Prodigy
OK got it to work,  After the Zones are created and saved, restart the Alro Q.  Guessing Q needs to restart to reset Pixel Change Detection for newly defined Zones.
Cyrano
Sorry, I don't understand. How can I define and save the zones, when every time I attempt to save even one zone, it disappears?
Cyrano
New camera, same behavior -- zones simply can't be saved. I've wasted many minutes, attempting to find a work-around, in vain.
This is very frustrating.
I just created and deleted zones with no problem using both the browser and Android app.  What have you been using?  Are you using the Save button at all?
Cyrano
I'm using a Windows desktop browser. Both Firefox and Internet Explorer show the same behavior.
And yes, I'm certainly using the Save command. That's the only way I could have shown the screenshots in my earlier post -- the post which shows a simple refresh of the page showing my "saved" zone is enough to lose that "saved" zone.
Cyrano
@jguerdat: Your mention of the Android app was the key. While the problem is still intractable in my browser, I had no problem creating and saving zones using the iOS app. Thanks!
@Netgear: I would still like this issue figured out for the Windows platform.
FWIW, my laptop is using Windows 10 and I generally use Chrome.  I just tried Firefox and it worked fine - created a zone, verified it was available in my modes and deleted it with no issues.
Try flushing the browser cache - maybe something needs refreshing.
Hula_Rock
Prodigy Prodigy
Prodigy
I am using chrome.  I noticed the same thing as mentioned before,  I can create the Zones, see tehm saved, but if you log out of the browser app, and log back in,  only 1 zone is saved.  The only way I got it to work is to create the zones, then restart Q via the web .
anhorn
Mine isn't working either.  I define a small area (cash register) but it is still detecting all other motion in the entire field of view.  I have wasted many hours as well.
Once you defined your zone, did you then assign it for use in your mode(s)?
anhorn
Yes, I have it assigned in the alarmed mode.
And I have the Activity Zones where you want motion to be detected to be just for the cash register vs "everywhere".
Yet, I keep getting updates for everywhere.
I guess the next step is to remove the camera from Settings, My Devices, reset the camera using the button until the LED flashes amber and resync.  Other than that, open a case with support.
