ARLO Q shutting down after a few minutes
  • 2 Replies
  • 2508 Views
Speddo
My Camera was working fine.  Broadcasting to my phone etc.  When I walked past it it made a whawha sound (Like you got a question wrong).  Then shut down permanently.  The next day I plugged it in and it started then shut down after about 1 minute.   Then reset and it stayed on for about 3 minutes and shut down.. Any ideas????
Sounds broken. Open a cases here: https://www.arlo.com/en-us/support/contact.aspx
Speddo,
Consider removing your Arlo Q and then go through the sync process again to further isolate the issue.
Log in to your Arlo account and navigate to Settings > My Devices > select the affected device > Remove Device.
Are you still seeing this behavior?
