  • 1 Reply
  • 2325 Views
Odysseus5
Hello,
I am using the geo fencing feature since i want my camera to activat eautomatically when i go away however what i noticed is that android some time shuts down the app by itself,
Is there a way that i keep it running always on my android so geofencing can reliabily work?
Thank you!
Thats more a setting in the androiod then the Arlo...
You'll have to check androids settings for sleep or similar,,,,  Also you must keep the app running in the background with your gps on or it will not function
