  • 1 Reply
  • 2715 Views
sdw49
Can I watch my Arlo Q 24/7? It keeps timing/dropping out after a couple of minutes. I have a standard coax camera at front door on small monitor. Turn monitor off when I sleep. Sort of want the same on the Q during my awake hours for the side of the house. AC powered, not batteries, so power not a problem. WiFi is strong, within 25'. Possible? Or call up only? Can I at least make it stay active on screen longer?
You can try on a tablet using the web address...but not sure as over time things have changed a few times...
We have in the past run it live view for more than a couple hours, then later it did n't seem to work... unsure anymore if the app/prgm will time out after an hour.
Nothing to hurt by trying it
