download from CVR
  • 6094 Views
Jordandawg05
are you able to download a portion of the CVR recording ?
with nest, i was able to download a clip or make a timelapse from the CVR record.  so i was wondering if there is something similar that i am not aware of with arlo Q
Not directly. You can stream via CVR and use a screen capture software package to record the display. I've done that a few times very successfully. Use full screen for best results.
Jordandawg05
thanks for the suggestion - if this is not one of the ehnacment that will becoming, it probably should. At least to keep up with the competition ( Nest).  i shouldn't be using a 3rd software to do it
Any particular software you use? i don't know of any right now.
Since I edit photographs and some video, I have various packages installed.  One of them is Roxio Creator NXT 3 and I use the screen capture utility that's part of the package.  I haven't researched other software but a Google of "windows video capture software" brings up various possibilities as well as this potentially interesting link:
http://reviews.gizmodo.com/windows-10-is-hiding-a-great-video-capture-tool-1719196149
If you have W10 installed, it may be worth a try.
  • 6095 Views
