arlo Q+ syncs & chimes but not found by arlo
  • 1 Reply
  • 1608 Views
  • 1 In Conversation
emoze
Q+ vcm3040s - was working fine on older netgear router, got new wifi router;
Q+ wouldn't sync with new router:  removed device, did factory reset, tried re-install - get blink amber, press sync get blink blue, hold to QR code get chime - all good to that point ...
- then arlo goes "searching" , finally get BUZZ BUZZ sound - then arlo says "unable to find your Arlo Q Plus."
p.s. - i have 4 arlo 2 - Pro's & they all work just fine with new wifi router
WHAT NOW?
similar problem thread with no solution posted
https://community.arlo.com/t5/Arlo-Q-Plus/Can-t-sync-my-Q-plus/m-p/1888828/highlight/false#M3191
emoze
 good news -  after several more resets & sync tries arlo finally discovers the Q+ 🙂
spent 3 hours with this d****m thing this morn 😬
emoze
