  • 1 Reply
  • 3682 Views
Mikemur
I need to extend the range so that the cameras in my gardens can connect with the base station.  What's the best extender, with firmware that is known to work?
Yon can not extend the range of your cameras with a wifi extender .... The only way to really expand your coverage is by adding a second base unit.
But , what you can do is centrally locate the base using an extender so the base has a better connection to all yor cameras if you don't do the first option.
Most any of the extenders on the market will work as long as they have an Ethernet port ( for the base) and thruput over 1 Mbs
  • 1 Reply
  • 3683 Views
