  • 2 Replies
  • 4603 Views
brantkrebs
I'm trying to find the MAC address for the POE adapter on an Arlo Q Plus. I have to connect the camera via ethernet connection, wifi is not an option where this camera will be located. The organization where this camera will be located won't allow anything on their network without the MAC address being whitelisted first. The wireless controller MAC is on the outside of the box and stamped underneath the base of the camera but that does me no good. Does anyone have any ideas?
I don't have a Q+ but I'd try it at home and check the router for the MAC address if it's not marked on the PoE adapter itself. Of course, your router would need to support PoE or use a switch that does.
Edit: On reflection, it may not be an issue of PoE since you can use the adapter just to use Ethernet without PoE. Just plug it in and check. Maybe IT will do that for you.
brantkrebs
That's what I ended up doing, taking it home and getting the mac off my router.
Thanks,
-Brant
  • 2 Replies
  • 4604 Views
