  • 1 Reply
  • 2843 Views
johnhwang
I was wondering if there any models that support multiple accounts, primary and/or guest, viewing the live feeds simultaneously. I was planning to purchase arlo q plus (for the POE) portion and possibly using some of the wireless arlo/arlo pro but I need to be able to live view simultaneously. I've searched through the forums but it appears that its not supported so I wanted to make sure before I spent a good chunk of change.
If I understand you correctly... The Q Plus would do it.
There can only be ONE primary account holder.  BUT, if you grant others access (GRANT ACCESS in settings ) multiple users can view at the same time.You also have some control over their admin privileges
Multi users on the PRO and Arlo can be an issue because if they are on battery, more users viewing can run the batteries flat in a short time ( tho the pro can be AC powered )
  • 1 Reply
  • 2844 Views
