  • 2 Replies
  • 1965 Views
Rserp
Hold in reset button for about 10 secs till led flashes...
sync as if new
If you do the above, also remove the camera from Settings, My Devices. However, all you really need to do is to either connect the camera to the new router through the existing cable (if that's how you had it connected before) or change the network in the camera settings. If you used the same SSID and passphrase from before, it should automatically connect with no intervention.
  • 2 Replies
  • 1966 Views
