  • 2 Replies
  • 3302 Views
BrianHack
Perhaps someone more tech-savvy can help with this.  I'm trying to link up the Arlo Q Plus on to my university's Wifi, but the network requires a username and a password.  It's not a home network where it's the network name and the password, but requires a username.  What's the best way to log on to this when the only option is to enter just a password?  I'm sure this is a very simple problem for many of you, but I'm not sure.  Wanted to check here first.  Many thanks for any assistance you may be able to provide.
You'll have to speak to IT to get this done.  There's no provision to support a login in any Arlo product.  You could potentially use a cell hotspot but there's the data usage to consider.
BrianHack
Many thanks, will do.  Best, Brian
  • 2 Replies
  • 3303 Views
