  • 2 Replies
  • 2044 Views
Danishcow
Hi all
What are the blue/green lines above the white CVR timeline?
I have CVR activated and I was playing around with unplugging the router to see if video is stored onto the SD. It seems that CVR footage (when disconnected from router) will not be placed into the SD. Only if the camera is "Armed" will the footage be placed on the SD. I reckon that the green line is for trigger events, but not sure about the blue line.
Could anyone clarify?
You get different colored lines on the CVR timeline for motion vs. sound activated recordings. Do you have both turned on in your modes?
No CVR video is ever recorded on the SD card - only motion/sound detection recordings.
Danishcow
Thanks!
  • 2 Replies
  • 2045 Views
