Arlo Q plus standard Plan stops recording if 1 GB reached
  • 2 Antworten
  • 3375 Aufrufe
  • 2 in Unterhaltung
otellodb
We are running 1 arlo plus q, which ist recording motion based.
From time to time the recording is stopped. Then we have to delete some older videos and recoding starts again.
I think the 1 GB limit is reached.
Is it possible to define an override mode. We are not interested in videos older than 3 days.
Even if i book a greater Plan, the problem is, that at reaching the limit, recoding stops for us.
What to do?
Any idea ?
2 ANTWORTEN 2
otellodb,
How many recordings are in your library? Are you sure you're reaching the limit?
Are you still able to produce a manual recording when you see this behavior?
JameC
otellodb
I think we have about 250 files a day and the system starts to get problems after 2.5 days.
Never tried manual recording, don't know how to.
But the amount of data we calculated is about 1 GB
otellodb
  • 2 Antworten
  • 3376 Aufrufe
  • 2 in Unterhaltung
