  • 4 Replies
  • 3664 Views
JayPow
I had my Arlo Q plus installed and running, connected with a powered ethernet cable. The camera is now completely non functional, no lights, nothing. I tested all connections, and also connected the camera with the alternate hdmi power adaptor. Still nothing. I also pressed the reset button on the camera, no luck.
dturner26
Check your power source. If you are sure there is a good power supply to the camera you should at least see it light. If it has power and still does not light I would believe the camera is defective.
Take the Q camera and power it from the included adapter ( instead of poe ) this will show if it's the poe cable power supply or the camera.
To reset the Q, it's hold in the reset for 10 secs till the front led flashes.
JayPow
I have tried all power options. Nothing seems to work, no power light from the camera. How can I initiate a replacement? This camera is only a couple of months old.
Open a case using the Contact Support link at the bottom of the desktop version of these pages.
  • 4 Replies
  • 3665 Views
