  • 1 Reply
  • 1735 Views
Knuckledragger
I am looking for a solution for a retail store.  Need 24/7 recording both inside and outside.  How can I include outdoor cameras that constantly record?
The Pro 2 cameras, when AC-powered, can be optioned to use CVR (continuous video recording). That storage is cloud-based, not local, which may be an issue for some. You would need to find the incident, view it through the app or web broswer and use 3rd party software to get a local recording. There are also limitations as to how long the cloud storage lasts, depending on your subscription.
Otherwise, the cameras will record on motion which may be useful forr helpting to zero in on the CVR recording.
  • 1 Reply
  • 1736 Views
