Arlo Q Plus longer mount
  • 2 Replies
  • 5306 Views
Jessicaw
Is there a mount available that would extend the camera? The neck on the built in mount is fairly sort, and we'd like to install it in a corner, but there are lighting and building structures in the way, so having a longer mount/arm would be needed and more aesthetically pleasing.
Right now you'd have to fashion your own mount, maybe using a block of wood.  Without a threaded hole like the wireless cameras, you'll have to be creative on your own.
you'll have to look around at extended camera mounts and then adapt/connect the normal base to it...
something like this , there are many types of ram mounts.;
flex mount
  • 2 Replies
  • 5307 Views
