  • 1 Reply
  • 1514 Views
Danishcow
Hello
I realize that if there is a trigger event, the camera will record to the SD card in addition to adding the video of the event to your "library" (the server) (i.e., if a sound or motion is detected). If I delete the video of the trigger event from my library (i.e., on the phone app), will it also delete it from the SD card? Or, do I have to manually take out the SD card and delete it?
You would need to manually delete it from the SD card.
  • 1 Reply
  • 1515 Views
