  • 1 Reply
  • 4123 Views
monsoon_qld
I've posted before about the Arlo Q Plus and SD card. From the answers I got (thank you to whoever that was) and the responses I read others getting, I see little point or use for using a SD card other than if the internet goes down. It's seems to me, and please correct me if I'm wrong, but if anything, buying a subscription or CVR plan is more value.
monsoon_qld,
These two options serve different purposes based on user needs. CVR allows for continuous video recording for a period of time (based on CVR subscription plan). SD card local storage stores triggered motion recordings with no limitation (other than the size of the SD card).
  • 1 Reply
  • 4124 Views
