36 Locations, 16 Cameras Each Location. How To Best Setup?
  • 2791 Views
Mehulc534
Need some help with this massive setup.
36 Locations
16 Cameras per Location
We need footage for 7 to 10 days on average, we could use the "motion detection" so it is only $2.50 per month, but what happens if we always have motion? Will it keep recording clips with a limit of 300 seconds and continue to creating a 2nd clip? We do not want to miss any video. We may need to export these videos for incidents that occur.
What is the best setup to go about this?
There is a short reset time between one recorded video triggered by motion and the next if motion continues.... Can be up to 10 secs.
if you need continuous recordings, these may not be suited for you
Mehulc534
What is the best solution for us to download videos then? I want a smooth and simple interface as Aaron provides for this solution
As long as you're referring to the recorded video clips, I have a Python script that can be used to automate the download of all videos from the day before. If the cameras are set up using different credentials, you'd have to run different instances since the credentials are embedded in the script.
If interested, PM me your email address.
  • 2792 Views
