- Community Home Home
- Community Browser:
- English
- English Q&A
- Arlo Events Q&A
- Arlo Pro3 Floodlight Q&A 2020.05.28
- Why is the Siren located in the mode and not in th...
Why is the Siren located in the mode and not in the utilities area Like the other devices.
Options
- Mark Question as New
- Mark Question as Read
I see that to turn the siren on or off you have to go into the mode not utilities. I accidentally set it off and had a hard time finding the on/off button. It would make it easier if all the options were in one place like the other devices. I have several devices that the options are in the utilities area.
Answer
0
Likes
Hi.. The Siren can be manually turned on by tapping the Shield icon on upper right corner of your Arlo App, or automatically via Mode rules. Once started, a red banner at the top of your Arlo App would indicate that siren is active along with a manual toggle to shutdown before preset duration.
Please check this KB for further info: https://kb.arlo.com/000062135/How-do-I-turn-the-siren-on-my-Arlo-Ultra-or-Arlo-Pro-3-camera-on-or-of...
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
0
Likes
