system stopped alerts with motion detection
  • 4 Replies
  • 1225 Views
JerryStone
My Arlo camera system stopped alerts with motion detection when armed. How can I reset my system to work again?
You can try removing one camera and resyncing it to see if that helps. I'll also tag the mods here to have them run a specific backend sync that usually helps. @JamesC , @ShayneS , @BrookeN
ShayneS
Hi @JerryStone
Can you reboot your base station and test again.
JerryStone
Hi ShayneS,
   I don't know why I didn't try the reboot first, but I did, and it solved my problem. Thanks!
ShayneS
@JerryStone
I made a small backend change, this is why I requested it, sorry for the confusion and thanks for the update!
