i set up my system and used my email. i didnt know you had to choose phone or email. how do i switch it so i can see the cameras on my phone? thanks
You just log intlk the app and all cameras will be displayed. As for notifications, you can set them using the Mode tab, click on your base and edit your modes. All such settings are in there. You should also learn to great your own modes so it's customized exactlbthe way you want it. Any camera without a rule in your new modes will be disarmed. Check the FAQs for details.
tommycass1,
You can use the same login information to sign in from any device after account creation. To sign in using your phone, download the Arlo mobile app from the app store and use the same email addressed you used to initially go though setup.
Please let us know if you need further assistance.
