recording when Internet outage
  • 4 Replies
  • 4707 Views
zorg54
Unfortunately the arlo USB his recording only a few days after an Internet Outage.
Why dont let arlo recording to ends off batteries ?
steve_t
Master Master
Haven't tested it for longer than a few minutes, sorry. My internet is rock steady. Guess I could just unhook the ethernet cable but can't really be bothered. Maybe @JamesC has more info
steve_t
Master Master
It should record until the USB drive is full and then overwrite the oldest videos (If you have the overwrite function enabled). If you're only getting a few days of recording, consider a larger USB drive. The max capacity the system can use is 2TB
zorg54
Hi Steve
In fact I have a very large recording capacity 1 TB and a lot off empty space on the device.
I have the overwrite enable
Steel no internet and full batteries on cameras.
But no recording
Hie that an option that NG has been concidering ?
zorg54
Steve
are you sure of that.  Arlo recording until end of days ? without internet ?
steve_t
Master Master
