"Firmware update in progress" on one camera
  • 1 Reply
  • 964 Views
larryminer
One of ny cameras gives the following message:  Firmware update in progress.  Do not remove batteries.
The message has been there for the last 2 days.  How do I clear this so I the camera will function?
brh
@larryminer
If the camera LEDs are no longer flashing blue and amber, you should be able to remove the batteries and start over. A couple of other things you can try is to first power cycle your base before removing and re-inserting the batteries. Worst case is to remove the camera from your devices and add again, just don't remove the batteries while the camera is flashing blue and amber.
Brian
