Cameras Keep Going Offline
After updated last time the cameras are offline more then they are online.anfball connections are ok and my internet is having zero issues. Also all cameras flash blue light really fast every 15 to 20 minutes all day and night for 30 seconds
The systems has 3 basic cams and 1 ask I pro the pro never flashes or fails. The base always goes to yellow on the middle light and the system never moves and never had issues till the last update.any ideas before I give go on arlos.
Stevesteffen,
The middle LED is the Internet Light. If it is showing yellow that means there is no connection to the internet. Have you tried to reboot the base station? Also, you can connect your base station to a different port on your router & replace the Ethernet cable.
