"Arlo GPS disabled. Tap to enable." Any fix to remove this notification?
Is there a fix to getting this message non stop? If I tap on the message, it just brings me to the app. No way to remove the notifications without removing all arlos notification, which obviously I'm not going to do.
Anybody else having this issue?
What phone/tablet are you using?
I'm thinking you have geofencing enabled, but the app doesn't have the rights needed to access your location.
One thing you can try is disabling geofencing (perhaps via my.arlo.com), and then try setting it up again in the app.
