  • 1 Reply
  • 1676 Views
checkingonyou
it gose offline when i go ck. it when im not home ...why
MarkC
Luminary
Luminary
Could you provide a little more info? It goes offline when you use the app when not on your home network?
What exactly happens, the more detail you can provide the easier it may be to help you.
Also, you can only conect to the base with one instance so either the app or via a computer.
I ditched Arlo! As a Company they hold their Customers/Us in complete contempt! We beta test producs for them, the products only work properly for ~70% of the time at best!
If you are serious about your home or work security then look elsewhere! Get a ip Camera System with an NVR and some Blink XT cameras to cover the places you cannot run a cable to. You will NEVER regret moving away from Arlo!
