issue without internet
  • 1 Reply
  • 1678 Views
Denis7
Why it's not possible to use the devices without internet, just to record for a period, different cameras on a USB disk.
To be able to check after few days in case of intrusion.
In terms of security there is no issue as the house is in an area without nothing (GSM, internet, ......)
Same issue also with internet, if your ISP goes down for any reason during several hours, you loose your monitoring and access to the camera, instead when your wifi is working well locally.
I regret to have bought this product ....;-)
Will be on ebay soon ...
While the Pro cameras/base will record to the USB backup if internet goes down( if prev armed ), you can not control the units or change settings .... it is the way the system was designed as cloud based.
