Hello, anybody know how to turn off automatic update notification for camera? Nag screen keeps popping up and will not let me see the video. Camera is at a remote site and is running off of USB for power which may explain why it does not update. I would still like to use camera with current firmware but app and web interface does not allow me to. If anybody know of a setting which prevents the pop up from appearing greatly appreciate it.
Strange that you can enough bandwidth to access the cameras but not enough to update. Pretty sure you have to do the update
There is no way to turn off the nag screen....
working ng outside the box already, have you tried to reboot the base remotely...that's how you force an update
Yes, tried power cycling both camera and base but update did not go through. I assume power cycling has same effect as reboot. camera is mounted at a difficult location to access and it does not have battery. Not having battery allows me to power cycle easily. Thanks for the input though. Just really annoying that I cannot use the camera until firmware is up to date.
yes.. that is one of the issues running from the usb port that was designed really for flashing the cam.
You would be better off with wiring to terminals internally ( all four neeed wiring, at aprox 8.5v ) and run a pigtail coaxial connector for removal when needed.
@TomMac, this is for a Pro, not the original.
oops ...oh well, sorry
ClintonU,
What is the signal strength like for this camera? It could be failing to update due to poor signal strength. Try bringing it close to the base station and see if you get different results.
10 feet with line of sight through window. camera is mounted on balcony. Basestation is wired ethernet. Signal strength is strong and I never had conneciton problem. I suspect it is not updating because I mounted camera without the battery to allow easy power cycling remotely. It is just annoying that web/app does not allow camera use without being forced to update. As a side note, I can see camera as long as I go though the motion of updating firmware with resulting camera rejecting the update but I lose about couple of minutes every time.
What internet connection speeds does your base get? www.speedtest.net when you're on site
						Apple HomeKit1
						Arlo Mobile App449
						Arlo Pro27
						Arlo Pro 21
						Arlo Pro 32
						Arlo Secure1
						Arlo Smart102
						Arlo Ultra1
						Arlo Web and Mobile Apps6
						Arlo Wire-Free10
						Before You Buy1,206
						Discovery1
						Features237
						Firmware1
						Firmware Release Notes119
						Hardware2
						IFTTT1
						IFTTT (If This Then That)48
						Installation1,430
						Installation & Upgrade1
						Online and Mobile Apps1,266
						Partner Integrations1
						Security1
						Service and Storage563
						Smart Subscription1
						SmartThings39
						Software & Apps1
						Troubleshooting7,335
						Videos1
