Assuming you're getting the notifications on the same email as what you use to set up the system, you'd either need to reset the system and use a different email account to set it up fresh or build a filter in your existing email account to forward the notifications to another account and maybe send them to the trash or another folder so you never see them.
vegasman1956,
You can change your email through your existing account, take a look here: How can I change my Arlo user ID?
Well, that would be easier than my silly suggestion...
