- 2
I have not yet bought a ARLO PRO. I have new siding on my house and do not want to drill holes into the siding for installation. What is the best way to install or attach the camera to siding without compromising or damaging the siding? Like to have something strong enough to hold it in place during high winds. Any suggestions?
I used siding hooks with the Arlo outdoor mount. Works great.
https://www.amazon.com/gp/product/B0051ZSIDK/ref=oh_aui_search_detailpage?ie=UTF8&psc=1
For me, I also didn't want to drill into the siding and had corner siding that was in an ideal location near my front entrance. If you have corner siding that is in a good spot try the following clamps. They have worked very well and I was even able to place them higher up so that they aren't easily accessible by thieves.
https://www.amazon.com/gp/product/B0714B2XX1/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
- 2
