arlos per line verizon
We purchased one Arlo pro from Verizon and they have told us today that EACH arlo has to have its own separate service line - looking at the site it says up to 5 - i am still under a return policy so if the best solution is return the one and purchase from this site I will - looking for advise please.
thanks!
Did you BUY an ARLO PRO or ARLO GO ??
TMK, Verizon doesn't sell the Pro but they do sell the GO ( which is a cellular based camera using a data sim )
And yes...if you purchased the GO, each one is it's own system ( and basicly phone number ) on the cellular network so each would have it's own service line.
PRO cameras hook into your home router ( via the base unit and ethernet ) ...you can use 5 cameras on the Basic ( free ) level with 7 days of rolling storage.
